Normal Topic multi node drag position (Read 2078 times)
ulthien
Oct 8th, 2012 at 4:02pm
hello,
when the user drags around e.g. several selected nodes together,
how to get the position of the top left corner? (in order to place e.g. a container node there)
i tried with:
                            var dragRect = new Rect();
                            foreach (DiagramNode node in Selection.Items)
                                dragRect.Union(node.Bounds);
                            var mp = new Point(dragRect.Left, dragRect.Top);
but this (i think) does not reflect the position of right now visually dragged nodes around...
cheers
Re: multi node drag position
Reply #1 - Oct 9th, 2012 at 6:23am
Try with diagram.Selection.Bounds. Or using your code, initialize dragRect with the Bounds of the first selected node instead of a new Rect, or otherwise the union might always include the (0,0) point.
ulthien
Reply #2 - Oct 9th, 2012 at 8:32am
thx, this is an excellent tip - it works Smiley
cheers
