Normal Topic Orientation of ShapeListBox (Read 2487 times)
saad
Oct 23rd, 2012 at 4:17am
How do I change the orientation of shapelistbox from vertical to horizontal?
Moreover, two or more shapelistbox on the page dont seem to hook up to the diagramview
Re: Orientation of ShapeListBox
Reply #1 - Oct 23rd, 2012 at 7:00am
There's no horizontal orientation supported officially, but if you are using Java mode you can set it as shown at http://mindfusion.eu/Forum/YaBB.pl?num=1308839087/6#6.
What do you mean by "hook up to the view" - doesn't drag and drop work when there are two list boxes on the page?
saad
Reply #2 - Oct 23rd, 2012 at 1:04pm
Drop drop seems to work if there is one shapelistbox on the page but if there are two or more, only one works.
This is quite important, I really needed the shapes to show in a horizontal manner rather than vertically due to the design of the page.
saad
Reply #3 - Oct 23rd, 2012 at 1:15pm
Solved.
This is solved, I managed to put two shapelistbox controls. I didnt set them up properly earlier.
