Normal Topic Netdiagram (Read 3197 times)
anita
Netdiagram
Oct 24th, 2012 at 2:36pm
We are using netdigram 2 purchased in 2007. A simple asp.net application is created with DiagramView & OverViewControl control.
The web page is working on firefox but it fails on IE8 & chrome.
AppletStarted script is not getting fired.
Error occurs before that. Which method or event fires AppletStarted event? Where can we write a code to check if applet is started in older version.
Please do the needful.
Re: Netdiagram
Reply #1 - Oct 25th, 2012 at 6:19am
I think after one of the minor JRE 1.6 updates the Java plugin started throwing exceptions instead of returning false for some checks done in NetDiagram's initialization scripts. If you don't wish to upgrade to a newer NetDiagram version, you could downgrade your Java version to vanilla 1.6 to work around that.
Otherwise you won't be able to use the standard AppletStarted script, but instead could run a timer that tracks when the applet's methods can be accessed successfully inside a try/catch block. E.g. once applet.getScriptHelper() returns an object, it should be safe to assume that the applet has loaded successfully.
