Normal Topic Can I ensure that each link uses a different anchor point on a node? (Read 4435 times)
Dan Beet
Oct 31st, 2012 at 10:12am
We are currently evaluating the DiagramLite control, to show what is effectively a UML class diagram (generated from some external metadata). We would like to auto arrange the diagram and have the links display separate from each other. When we use the OrthogonalLayout (the only layout that seems to work well in our scenario) all the links overlap and their text becomes unreadable.
Is there something we can do to solve this? We have tried creating our own Anchor pattern and calling ReassignAnchorPoints() on each node after we have created the links, but this does not seem to help our issue.
We do not allow users to rearrange the diagram at the moment, as it is read-only.
Thanks, Dan
Re: Can I ensure that each link uses a different anchor point on a node?
Reply #1 - Oct 31st, 2012 at 12:05pm
Could you attach a sample xml file showing what kind of diagrams you need to arrange?
Dan Beet
Reply #2 - Oct 31st, 2012 at 1:12pm
I have attached an exported XML from the control (using diagram.SaveToXml(Stream)). We generate the nodes and links in code, but I assume that the export will have all the properties you need?
The custom shape is simply there so that I could use a templated control with bindings to the data context to our model objects - maybe we can do the same thing with a ControlNode?
public class DataTypeNode : ShapeNode {
           public DataTypeNode(Diagram parent) : base(parent) {
                 DefaultStyleKey = typeof (DataTypeNode);
           public DataTypeNode(ShapeNode prototype) : base(prototype) {
           public DataTypeNode() {
The diagram XAML is:
<mfd:Diagram x:Name="_modelDiagram" MinWidth="200" MinHeight="200" AutoSnapLinks="False" AutoScroll="True"
                       ShowGrid="False" AutoAlignNodes="False" ShapeBrush="White" LinkBrush="Black" AlignToGrid="False"
                       Behavior="Modify" AllowUnconnectedLinks="False" AllowInplaceEdit="False" RouteLinks="True"
                       DynamicLinks="True" ModificationStart="AutoHandles" LinkCrossings="Arcs" BackBrush="White"
                             FontSize="12" ShapeHandlesStyle="EasyMove" />
With the following set in the code behind constructor:
                 _modelDiagram.AdjustmentHandlesSize = 10;
                 _modelDiagram.DynamicLinks = true;
                 _modelDiagram.LinkStyle = LinkStyle.Cascading;
                 _modelDiagram.RoutingOptions.Anchoring = Anchoring.Reassign;
                 _modelDiagram.RoutingOptions.TriggerRerouting = RerouteLinks.WhenModified;
I have disabled node/link creation and deletion using the *Creating/*Deleting events and args.CancelDrag().
The custom anchor pattern is created like this:
AnchorPattern = new AnchorPattern("DataTypeAnchorPattern");
                 for (var x = 20; x <= 80; x += 10) {
                       AnchorPattern.Points.Add(new AnchorPoint(x, 0, true, true, MarkStyle.Cross));
                       AnchorPattern.Points.Add(new AnchorPoint(x, 100, true, true, MarkStyle.Cross));
                 for (var y = 20; y <= 80; y += 10) {
                       AnchorPattern.Points.Add(new AnchorPoint(0, y, true, true, MarkStyle.Cross));
                       AnchorPattern.Points.Add(new AnchorPoint(100, y, true, true, MarkStyle.Cross));
To arrange the diagram I have used:
var layout = new OrthogonalLayout {
     Anchoring = Anchoring.Reassign,
     KeepGroupLayout = true,
     MultipleGraphsPlacement = MultipleGraphsPlacement.VerticalSortDescending,
     Refine = true,
     Padding = 150,
     Margins = new Size(100, 100),
layout.Arrange(_diagram)
_diagram.ResizeToFitItems(100);
_diagram.RouteAllLinks();
_diagram.UpdateLayout();
diagram_export_xml.txt (Attachment deleted)
Reply #3 - Oct 31st, 2012 at 8:09pm
Check if this approach will work for you, without using anchor points. The code runs OrthogonalRouter to distribute links after applying the layout, and then rotates labels of vertical links to prevent them from overlapping with adjacent links between the same pair of nodes.
	Refine = true,
	Padding = 150,
layout.Arrange(diagram);
new OrthogonalRouter().Arrange(diagram);
foreach (var link in diagram.Links)
	if (link.StartPoint.X == link.EndPoint.X)
		link.TextBlock.RenderTransform = new RotateTransform
			Angle = 90,
			CenterX = link.TextBlock.ActualWidth / 2 + 10,
			CenterY = link.TextBlock.ActualHeight / 2
Dan Beet
Reply #4 - Nov 1st, 2012 at 5:48pm
That worked perfectly. Thank you very much for your help.
