Normal Topic Export to PDF without empty pages (Read 2440 times)
Patrik
Nov 6th, 2012 at 3:00pm
Hi!
We're using NetDiagram 3.1.1 for .NET 3.5 for PDF-generation (MindFusion.Diagramming.Export.PdfExporter on MindFusion.Diagramming.Diagram()).
Is there a way to remove empty/blank pages so they do not end up in the resulting PDF?
Please let me know if you need more info!
BR
/Patrik
Re: Export to PDF without empty pages
Reply #1 - Nov 6th, 2012 at 3:43pm
You could call Diagram.ResizeToFitItems before exporting, and restore Bounds to its previous value afterwards.
Patrik
Reply #2 - Nov 7th, 2012 at 11:39am
Thanks for quick answer!
We are already doing something like this. The problem is that if we have a workarea 2x2 A4-pages and a diagram that streches over the two in the top and down to the last in the bottom row (1, 2 and 4), we will get 4 pages in PDF where the third is empty.
[1][2]
[3][4]
Can we get rid of this empty page so it does not appear in the PDF?
/Patrik
Reply #3 - Nov 8th, 2012 at 3:40pm
You can't skip such pages. You might try using a third party PDF library to remove them after the diagram PDF is generated.
