Normal Topic TextPadding and ResizeToFitText issue (Read 2678 times)
jlj30
Nov 6th, 2012 at 10:28pm
I am successfully using ResizeToFitText, but I'd like some padding at either the right or left side of the text.
I've tried placing the TextPadding before and after the ResizeToFitText without luck.
Any ideas on how I can get the padding I'm looking for.
See attached screenshot.
I've also included the code that generates the nodes.
The diagram has a centered TreeLayout applied to it.
Thanks in advance
Jim
protected ShapeNode createNode(Diagram diagram, String nodeText, Boolean expandable, StringAlignment textAlign)
        Factory factory = diagram.Factory;
        ShapeNode node = factory.CreateShapeNode(0, 0, 100, 10, Shapes.RoundRect);
        node.Text = nodeText;
        node.Font = new Font("Arial", 12, System.Drawing.FontStyle.Bold);
        node.TextFormat.Alignment = textAlign; // Far = right; Near = left
        node.TextFormat.LineAlignment = StringAlignment.Center;
        node.TextFormat.FormatFlags = StringFormatFlags.NoWrap;
        node.Pen.Color = Color.White;
        node.ShadowOffsetX = 0;
        node.ShadowOffsetY = 0;
        node.Brush = new MindFusion.Drawing.SolidBrush(Color.WhiteSmoke);
        node.Expandable = expandable;
        node.TextPadding = new MindFusion.Diagramming.Thickness(10f, 1f, 10f, 1f);
        //node.ResizeToFitText(FitSize.KeepWidth);
        node.ResizeToFitText(FitSize.KeepHeight);
        return node;
Re: TextPadding and ResizeToFitText issue
Reply #1 - Nov 7th, 2012 at 11:34am
We haven't implemented text padding in Java. For the time being, set Alignment to Center and text should look correctly padded for your nodes.
jlj30
Reply #2 - Nov 7th, 2012 at 2:16pm
Yes, you're right.
Since I am resizing the shape to "fit" the text, using a center'd alignment works as I wanted.
Thanks for pointing out the obvious to me Smiley
Jim
