Normal Topic Diagram.Links.Clear() bug? (Read 1729 times)
j poz
Nov 21st, 2012 at 4:36pm
We recently upgraded to MindFusion FlowChart.NET Pro 6.0, and in our code the one call to Diagram.Links.Clear() no longer removes the items in the links collection.
Re: Diagram.Links.Clear() bug?
Reply #1 - Nov 21st, 2012 at 6:35pm
This shouldn't have worked in previous versions either. If you need to remove everything, call the ClearAll method of Diagram. Removing all links but no nodes should look like this:
var allLinks = diagram.Links.Clone();
foreach (DiagramLink link in allLinks)
	diagram.Links.Remove(link);
j poz
Reply #2 - Nov 21st, 2012 at 6:57pm
Okay, that'll work. Thanks.
