Normal Topic How to cotrol points when modifying a link? (Read 1329 times)
CanadaProgrammer
Dec 12th, 2012 at 11:23pm
I try to modify values of points of a link when user
is modifying a link (I mean in LinkModifying event).
The problem is that LinkModifying is not always raised
when the link is not on any DiagramNode shape. Of course
I set AllowUnconnectedLink to false. So how to control
it in this situation?
Re: How to cotrol points when modifying a link?
Reply #1 - Dec 13th, 2012 at 7:20am
This is a validation event and the control won't raise it if it knows that the link cannot be dropped at current position anyway. You could set AllowUnconnectedLinks to true, and set e.Cancel in LinkModifying / LinkCreating handlers if e.Origin or e.Destination is null. If you have a custom link class, a better place to update the link points might be the UpdateModify method.
