Normal Topic Userstring not saved with SavetoXML (Read 5321 times)
Pat
Dec 19th, 2012 at 2:39pm
Is there a way to save the userstring and userdata along with the rest of the XML?
Re: Userstring not saved with SavetoXML
Reply #1 - Dec 19th, 2012 at 5:51pm
The XML format was ported from our .NET flow diagramming control which does not have such properties, and apparently our developers omitted them from the ActiveX one. Now this version should save them as expected:
https://mindfusion.eu/_beta/fcx_user.zip
Pat
Reply #2 - Jan 7th, 2013 at 4:12pm
Thank you for your response. Currently i'm using the 64 bit dll. I've just installed the FlowChartX professional edition full version which we just bought. Do you also have a 64 bit edition (no trail version)?
Reply #3 - Jan 8th, 2013 at 7:28am
You can find updated licensed version for both 32 and 64 bits on the private messages page - follow the link at top of the forum.
Pat
Reply #4 - Jan 8th, 2013 at 8:51am
Hi Stoyan,
This upgrade works like a charm. Now i can store extra information (in XML format) in the userstring.
Thanks for the quick response.
Best whishes for 2013,
Pat
« Last Edit: Jan 8th, 2013 at 12:25pm by Pat »
