Normal Topic How to use TreeLayout so it doesn't rearrange nodes horizontally (Read 2769 times)
Rennie
Jan 2nd, 2013 at 2:01am
I have a diagram that represents a company organization chart, somewhat like the composite node demo program. I have a "Format Chart" button to let the user tidy up the layout, using the TreeLayout class.
My problem is that this apparently always places "sister nodes" (nodes with same parent) in the order in which they were created, even if the user has later changed his/her mind and rearranged them horizontally. At least when I use TreeLayoutBalance.Original, which is default - the other options do not seem relevant for my application.
Is there some way to tell TreeLayout to not reorder sister nodes horizontally?
Re: How to use TreeLayout so it doesn't rearrange nodes horizontally
Reply #1 - Jan 2nd, 2013 at 9:50am
The order of a node's children in the tree corresponds to the order of the node's OutgoingLinks, so you could sort them by their destination positions before applying TreeLayout:
foreach (var node in diagram.Nodes)
	var links = new List<DiagramLink>(node.OutgoingLinks);
	links.Sort((l1, l2) => l1.EndPoint.X.CompareTo(l2.EndPoint.X));
	node.OutgoingLinks.Clear();
	foreach (var link in links)
		node.OutgoingLinks.Add(link);
new TreeLayout().Arrange(diagram);
Rennie
Reply #2 - Jan 2nd, 2013 at 10:35pm
Thanks, Stoyo.
Just in case anyone else encounters this problem, and are still desperately clinging C# 2.0 syntax, here's my version:
         foreach (DiagramNode diagramNode in _diagramView.Diagram.Nodes)
            if (diagramNode.OutgoingLinks.Count >= 2)
               List<DiagramLink> diagramLinks = new List<DiagramLink>(diagramNode.OutgoingLinks);
               diagramLinks.Sort(delegate(DiagramLink link1, DiagramLink link2)
                                 { return link1.EndPoint.X.CompareTo(link2.EndPoint.X); });
               diagramNode.OutgoingLinks.Clear();
               foreach (DiagramLink diagramLink in diagramLinks)
                  diagramNode.OutgoingLinks.Add(diagramLink);
But I do have a suggestion. I can imagine a situation where you want to format the tree the way I'm requesting, but would prefer to not reorder the nodes. How about adding a new option
TreeLayoutBalance.Current
(or something else) that does that?
Reply #3 - Jan 3rd, 2013 at 11:25am
We'll have it in mind for next releases Smiley
Reply #4 - Jan 8th, 2013 at 8:25am
This version adds a Preserve option to TreeLayoutBalance, which should preserve the initial geometric order of nodes in the tree:
https://mindfusion.eu/_beta/fcnet_treebalance.zip
It does not work for radial layouts at this time.
Rennie
Reply #5 - Jan 8th, 2013 at 9:14am
If by "initial" order you mean the current order when you issue the TreeLayout operation, then that sounds great. Thank you very much.
