Normal Topic CompositeNode - SavetoString and LoadFromFile (Read 1249 times)
AtlantaCoder
Jan 8th, 2013 at 3:03am
I have a demo application where i'm using composite node.
1)public class Base: CompositeNode
2)public class DerivedOne: Base
3)public class DerivedChild1: DerivedOne
4)public class DerivedChild2: DerivedOne
I have registered and defined public constructor it fails during loading from file.
I needs to know if i'm missing something ctor initialization?
Any sample with nested hierarchy would be of great help.
Re: CompositeNode - SavetoString and LoadFromFile
Reply #1 - Jan 8th, 2013 at 6:56am
In what manner does it fail? Verify the following:
- RegisterItemClass should be called for each custom class before calling serialization methods
- when loading, the diagram looks for public no-arg () or (Diagram) constructors in the class via reflection
- check if fields serialized from custom SaveTo and LoadFrom methods are listed in the same order and the read/write methods used for each field have matching types.
See the Scripting sample project and EmployeeNode.cs in the C#/Demo project.
