Normal Topic Serialization Problem (Read 1541 times)
lyrock
Jan 3rd, 2013 at 5:23pm
I saved a sketch with serialization from a design interface created with Mindfusion.
I tried to open that sketch file in another independent runtime interface (also created with Mindfusion), and came across the following errors:
Any suggestion? thanks.
Re: Serialization Problem
Reply #1 - Jan 3rd, 2013 at 5:45pm
You will have to move any types used as Tag values or hosted controls to a shared assembly referenced by both applications of yours, or serialize tags / controls in text form by handling the SerializeTag and DeserializeTag events, or respectively SerializeControl and DeserializeControl.
lyrock
Reply #2 - Jan 3rd, 2013 at 10:14pm
Thank you.
It helps and got problem solved.
Happy New Year!
Stoyo wrote on Jan 3rd, 2013 at 5:45pm:
