Normal Topic two shapenodes link to one shapenode (Read 2787 times)
Green
Jan 4th, 2013 at 7:33am
there is a shapenode ,I wish two shapenodes link to the shapenode ,one is dash ,the other is Solid ,but the link can not be Overlapped ,LinkStyle.Cascading ,what should I do?
Re: two shapenodes link to one shapenode
Reply #1 - Jan 4th, 2013 at 10:39am
How are these three nodes located relatively to each other? You might assign different positions to the links end points to avoid overlapping the segments adjacent to nodes. To avoid overlapping internal segments, try calling Diagram.RouteAllLinks().
Green
Reply #2 - Jan 5th, 2013 at 1:07am
thank you ! but how can I assign different positions to the links end points ?
Reply #3 - Jan 7th, 2013 at 7:05am
After applying the layout you are using, call this method for all nodes, assuming links have three segments:
void OffsetDashedLinks(DiagramNode node)
	foreach (DiagramLink link in node.OutgoingLinks)
		if (link.Pen.DashStyle != DashStyle.Solid)
			var points = link.ControlPoints;
			var n = points.Count - 1;
			var xOffset = (points[0].X > points[n].X) ?
				-1 :	// destination is to the left of origin
				+1;		// destination is to the right of origin
			points[0] = new PointF(points[0].X + xOffset, points[0].Y);
			points[1] = new PointF(points[1].X + xOffset, points[1].Y - 1);
			points[2] = new PointF(points[2].X + xOffset, points[2].Y - 1);
			points[3] = new PointF(points[3].X + xOffset, points[3].Y);
			link.UpdateFromPoints();
