Normal Topic Container expand/collapse hit test? Cursor? (Read 1416 times)
j poz
Jan 8th, 2013 at 5:57pm
Is it possible to customize the hit test area of a container's expand/collapse button? We would like to make the active hot spot a little bigger.
Also, can the mouse cursor be customized when it is over this hotspot area?
Re: Container expand/collapse hit test? Cursor?
Reply #1 - Jan 8th, 2013 at 6:55pm
At this time it depends only on the container's CaptonHeight property, so you might set it to a larger value. Changing the cursor can be done from MouseMove handler:
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	diagramView.OverrideCursor = null;
	var point = diagramView.ClientToDoc(e.Location);
	var ctr = diagram.GetNodeAt(point) as ContainerNode;
	if (ctr != null)
		var rect = ctr.Bounds;
		if (point.X > rect.Right - ctr.CaptionHeight &&
			point.Y < rect.Top + ctr.CaptionHeight)
			diagramView.OverrideCursor = Cursors.Cross;
