Normal Topic Error in Iexplore 9 (Read 2650 times)
hans
Error in Iexplore 9
Jan 15th, 2013 at 3:00pm
I am trying to use canvas-mode with diagramming.js
When I have a page with the diagram on it, its shows in safari, opera and, but I always get an error in iexplore:
"runtime-error Microsoft Jscript: the property or method [addeventListener] is not supported by this object.
The script debugger halts in the script  Type.registerNamespace("MindFusion.Collections") on:
s.addEventListener("touchstart",Function.createDelegate(this,this.onTouchStart),
false)
When I try the fractal-layout sample, the same happens in Iexplore, while it works well in firefox and opera.
Do you have any idea what is wrong ?
Re: Error in Iexplore 9
Reply #1 - Jan 15th, 2013 at 3:14pm
Check if your IE isn't running with Compatibility View enabled (the broken page icon) - this mode does not support canvas objects.
hans
Reply #2 - Jan 15th, 2013 at 7:56pm
it helped, Thanks.
