Normal Topic Multiline text of link not exported (Read 3389 times)
AD2012
Jan 16th, 2013 at 3:42pm
Dim loExporter As New PdfExporter
loExporter.Export(Diagram1, SaveFileDialog1.FileName)
A diagramlink is containing a text of multiple lines. Only first line is exported to the pdf file.
Version:
Mindfusion.Diagramming for Winforms (Pro Edition)
.NET 4.0
MindFusion.Diagramming.Export.Pdf.dll File version 5.5.0.25332
Re: Multiline text of link not exported
Reply #1 - Jan 17th, 2013 at 7:42am
Exporting multiple lines of text for links seems to work fine in latest version. If you don't want to upgrade, replace your link texts with ShapeNodes before exporting:
Diagram copy = new Diagram();
copy.LoadFromString(diagram.SaveToString());
foreach (DiagramLink link in copy.Links)
	ShapeNode label = copy.Factory.CreateShapeNode(0, 0, 100, 100);
	label.Text = link.Text;
	label.Transparent = true;
	label.ResizeToFitText(FitSize.KeepRatio);
	label.Move(
		link.Bounds.X + link.Bounds.Width / 2 - label.Bounds.Width / 2,
		link.Bounds.Y + link.Bounds.Height / 2 - label.Bounds.Height / 2);
	link.Text = "";
pdfExporter.Export(copy, sfd.FileName);
AD2012
Reply #2 - Jan 17th, 2013 at 10:40am
Thanks for your reply, but it seems not working correctly. See attachments:
diagram : diagram view
pdf : export to pdf
one link is missing a part ("Default" => "Defa")
another link has bad wrapping
AD2012
Reply #3 - Jan 17th, 2013 at 11:00am
I changed it a little bit, it seems to work:
            Dim copy As Diagram = New Diagram()
            copy.LoadFromString(Diagram1.SaveToString)
            For Each link As DiagramLink In copy.Links
                Dim label As ShapeNode = copy.Factory.CreateShapeNode(0, 0, 500, 500)
                label.Font = link.Font
                label.Transparent = True
                label.Move(link.Bounds.X + link.Bounds.Width / 2 - label.Bounds.Width / 2, _
                link.Text = ""
            Next
            loExporter.Export(copy, SaveFileDialog1.FileName)
Thanks.
