Normal Topic image is not show according to shape in background. (Read 6628 times)
Yogendra
Jan 29th, 2013 at 2:42pm
Hi
I am working diagramming.mindfussion diagram. I can add shape node in diagram like as circle, triangle, rectangle etc. i can assign image in shape. code is here:-
Dim shapeNode as shapeNode=diagram.Selection.Item(0)
shapeNode.Image=bitMapImage
//bitmapImage is object of BitMapImage class and has image which i want to be assigned Image property of shape node.
This working is fine with rectangle shape but circle and other shapes, Image is always rectangle , not according to shape as circle and triangle.
Thanks in advance  Smiley
Re: image is not show according to shape in background.
Reply #1 - Jan 29th, 2013 at 7:29pm
You could set the node's Clip property and update it from NodeModifying events:
node.Clip = node.Shape.CreateOutlineGeometry(
	node.Bounds.Width, node.Bounds.Height, diagram.MeasureUnit);
Yogendra
Reply #2 - Jan 30th, 2013 at 5:27am
Thanks God member.
It's solved my lots of problem.  Wink
Yogendra
Reply #3 - Jan 30th, 2013 at 6:38am
Hi stoyo,
Your solution is working fine. Thanks a lot. But when I re-size my node by dragging it through mouse, the image didn't show at the time of dragging, but as I release the mouse button, the image gets re-sized to its new dimension and is start showing in the the diagram. How to make the image re-size smoothly with the control it is assigned to?  I'll be thankful to you if you help me in solving this issue too.
Reply #4 - Jan 30th, 2013 at 7:14am
Do you call this also from the NodeModifying handler?
