Normal Topic Overview and ClientSideMode="ImageMap" (Read 4996 times)
jlj30
Jan 29th, 2013 at 10:31pm
What is required to get the Overview to work when using ClientSideMode="ImageMap"?
Should I declare an Overview control or specify ShowOverview="true" on the DiagramView declaration or both?
Do I need an InteractivityExtender control?
I have been able to get the Overview image to appear, but is not functional.
Please clarify how the Overview should be implemented with ImageMap mode.
Thanks.
Jim
Re: Overview and ClientSideMode="ImageMap"
Reply #1 - Jan 30th, 2013 at 6:42am
Use Overview with OverviewExtender.
jlj30
Reply #2 - Jan 30th, 2013 at 8:52pm
I tried adding the OverviewExtender, but without success.
Here's my code:
Code (HTML)
<div style="clear: both; margin-top: 10px; margin-left: 10px; margin-right: 10px;
                    position: absolute;  z-index: 90001;">
                    <ndiag:Overview ID="Overview1" runat="server" DiagramViewID="DiagramView3" JarLocation="./Java/JDiagram.jar"
                        FitAll="true" Visible="true" Style="background-color: white; width: 200px; height: 200px;" />
                    <ndiag:OverviewExtender ID="OverviewExtender1" runat="server" TargetControlID="Overview1" />
                </div>
                <div style="z-index: 90000;">
                    <ndiag:DiagramView ID="DiagramView3" runat="server" Behavior="Pan" ClientSideMode="ImageMap"
                        JsLibraryLocation="./Js/MindFusion.Diagramming.js" JarLocation="./Java/JDiagram.jar"
                        AppletStartedScript="onAppletStarted" ShowScrollbars="true" ShowOverview="true"
                        OverviewFitAll="true" OverviewTitle="Navigator">
                    </ndiag:DiagramView>
                </div>
As you can see I'm placing the overview on top of the diagram using the "absolute" positioning.  I removed that, but the overview still does not function.
I've also attached a screenshot of what I'm seeing.
A part of the overview images appears, but you can't interact with it.
Suggestions?
Jim
Reply #3 - Jan 31st, 2013 at 3:06pm
At this time the overview control is rendered entirely on the server with sizes known while processing the page from ASP code, and will show the tracking rectangle correctly only if the DiagramView's Width and Height properties are set in pixels. If you don't set them, you could do something like this from JavaScript as a work-around:
var tracker = $find('OverviewId').tracker;
if (tracker) {
    tracker.style.width = "50px";
    tracker.style.height = "50px;
You will also have to set absolute position for the overview to fix some interaction problems with the tracking rect when the parent div is absolutely positioned:
                        FitAll="true" Visible="true" Style="background-color: white; width: 200px; height: 200px; position: absolute;" />
jlj30
Reply #4 - Feb 1st, 2013 at 4:27pm
I'm a bit confused (nothing new).
I placed the javascript you provided in the PageLoad() event.
I added an OverviewExtender.
I update the Overview to include position: absolute as suggested.
I still have the same issue as illustrated from the screenshot I provided in an earlier post.  The behaviour has not changed and the Overview remains nonfunctional.
Any suggestions?
Jim
Here's what I have now:
Code (Javascript)
function PageLoad()
                var tracker = $find('Overview1').tracker;
                if (tracker) {
                    tracker.style.height = "50px";
Code (HTML)
                        <ndiag:OverviewExtender ID="OvExt1" TargetControlID="Overview1" runat="server" />
                </div>
                        AppletStartedScript="onAppletStarted" ShowScrollbars="true" ShowOverview="false"
                </div>
Reply #5 - Feb 5th, 2013 at 3:07pm
If you call alert() from within the if (tracker) block, does it show up? If it doesn't, then your load handler runs before the overview's one and the tracker div hasn't been created yet. In such case, try attaching the load handler from a script tag at the bottom of the page.
Our developers have updated the overview scripts for next version to calculate the size on client side. With the assemblies below the tracker rectangle should appear correctly for whatever size the overview and diagram view have inside the browser, and will also update in response to resize events:
https://mindfusion.eu/_beta/netdiag5_imgmap_ovw.zip
jlj30
Reply #6 - Feb 5th, 2013 at 5:52pm
Stoyan,
The alert is not firing, so I moved the code to the bottom of the page as you suggested - it still does not fire!
I also installed the beta binaries that you provided.
Any ideas on what to try next?
Jim
Reply #7 - Feb 5th, 2013 at 6:03pm
Have you attached that PageLoad function to the html's onload event? You shouldn't need that work-around though if your project uses the new binaries, check if the site's bin folder contains them rather than an older version.
jlj30
Reply #8 - Feb 5th, 2013 at 7:33pm
I am definitely using the new binaries.
I am now getting some build errors:
Looks like the following are no longer supported, or implemented in some other manner:
node.ZBottom();
link.Style = LinkStyle.Polyline;
link.Style = LinkStyle.Bezier;
I was able to find the new form of the following statement.
//diagram.LinkStyle = LinkStyle.Cascading;
diagram.LinkCascadeOrientation = Orientation.Auto;
How do I now code for the above 3 statements that no longer work?
Thanks again
Jim
Reply #9 - Feb 6th, 2013 at 6:47am
node.ZBottom(false);
link.Shape = LinkShape.Polyline;
link.Shape = LinkShape.Bezier;
