Normal Topic Using magnetic line of the ruler component (Read 2273 times)
Jan Meyer
Feb 5th, 2013 at 7:14pm
When use the magnetic lines from the ruler component to move diagram items neither DiagramAdapter.nodeModified() nor DiagramAdapter.selectionMoved is being invoked.
My problem:
Every time a diagram item has been moved I need to update something else which is related to this item.
Is there solution for my Problem?
Jan
Re: Using magnetic line of the ruler component
Reply #1 - Feb 6th, 2013 at 8:32am
This version raises nodeModified:
https://mindfusion.eu/_beta/jdiag401.zip
