Normal Topic Is there an equivalent to "bringIntoView" when in ImageMap mode? (Read 3062 times)
jlj30
Feb 5th, 2013 at 8:51pm
In another post that I created, I was provided with a function that used the bringIntoView method.  This has served me well when using the JavaApplet.
I would like to be able to do the same for my users that are in ImageMap mode.
Is there a method or approach that I can use to accomplish this.
Code snippets are always welcomed Smiley
Thanks in advance.
Jim
Re: Is there an equivalent to "bringIntoView" when in ImageMap mode?
Reply #1 - Feb 6th, 2013 at 3:15pm
If you know on the server side how big your view will be in the browser, call the ClientToDoc method to find its size in diagram's measure units, and then set
view.ScrollX = node.GetCenter().X - viewSize.X / 2;
view.ScrollY = node.GetCenter().Y - viewSize.Y / 2;
jlj30
Reply #2 - Feb 10th, 2013 at 5:12pm
Hi Stoyan,
Thanks for the code, but I'm a bit confused about how to make it work.
Here's what I have so far, which creates a small window (500px X 500px), but the node is not visible in this window (not even close actually).
In fact the slider on the horizontal scrollbar is at the far left, and the slider on the vertical scrollbar is at the top - so it doesn't look like the scroll position was adjusted at all.
Is there something I need to do after setting the view's ScrollX/Y?
Thanks again.
Jim
Code (C++)
DiagramView3.Height = Unit.Parse("500px");
        DiagramView3.Width = Unit.Parse("500px");
        DiagramNode root = diagram.Nodes[0]; // Locate the root node which is the Process Name
        System.Drawing.RectangleF viewSize = DiagramView3.ClientToDoc(new System.Drawing.Rectangle(0, 0, 500, 500));
        DiagramView3.ScrollX = root.GetCenter().X - viewSize.X / 2;
        DiagramView3.ScrollY = root.GetCenter().Y - viewSize.Y / 2;
[/code]
And here's the DiagramView declaration:
Code (HTML)
<ndiag:DiagramView ID="DiagramView3" runat="server" Behavior="Pan" ClientSideMode="ImageMap"
                        JsLibraryLocation="./Js/MindFusion.Diagramming.js" JarLocation="./Java/JDiagram.jar"
                        AppletStartedScript="onAppletStarted" ShowScrollbars="true" ShowOverview="false"
                        OverviewFitAll="true" OverviewTitle="Navigator" Diagram-EnableStyledText="true" ZoomFactor="100">
                    </ndiag:DiagramView>
Reply #3 - Feb 11th, 2013 at 1:55pm
Actually ScrollX and ScrollY were not used in ImageMap mode. This version should let you set them from the server side:
https://mindfusion.eu/_beta/netdiag5_scroll.zip
With an older version you could run a client-side script that sets srollLeft and scrollTop on the DiagramView's div, assigning the result of DocToClient(scrollPos) to them.
