Normal Topic how to redraw Expandbutton on existing nodes (Read 3975 times)
hans
Feb 7th, 2013 at 12:02pm
After loading a diagram form string, i use the code below to reposition the expandbutton. (using 1.5 beta)
But the new position of the existing nodes is only visible after moving the node.
How can I update the new position?
i.e. node.invalidate() or diagram1.invalidate() doesn't help.
var ExpandButton = MindFusion.Diagramming.ExpandButton;
var oldGetRect = ExpandButton.prototype.getRect;
ExpandButton.prototype.getRect = function ()
     var rect = oldGetRect.apply(this);
     rect.y = this.node.bounds.y;
     return rect;
Re: how to redraw Expandbutton on existing nodes
Reply #1 - Feb 8th, 2013 at 7:47am
Replace ExpandButton.getRect before loading the diagram and the icons should appear as expected. Or otherwise call node.expandButton.updateContent() before calling invalidate() on the node or diagram.
hans
Reply #2 - Feb 8th, 2013 at 4:26pm
As I load the diagram from code-behind, i can't find a way to Replace ExpandButton.getRect before loading the diagram.
Then after loading the diagram node.expandButton.updateContent() doesn't seem to have any effect.
This does work:
node.setExpandable(false); node.setExpandable(true);
Reply #3 - Feb 11th, 2013 at 7:31am
You can replace the function from a page load event handler attached before the diagram's own load scripts are attached. That should ensure your handler runs before the diagram's one, which loads data from the server and draw the nodes and their +/- icons:
<body onload="onLoad()">
<ndiag:DiagramView ClientSideMode="Canvas" ... />
function onLoad()
		  return rect;
Instead of setting <body onload>, you could attach the handlers dynamically (in unobtrusive javascript manner) from a <script> tag appearing before the <DiagramView>.
You can update the location for an individual node using the updateLocation method actually, not updateContent:
function onNodeClicked(sender, args)
		return rect;
	var node = args.getNode();
	node.expandButton.updateLocation();
	node.invalidate();
