Normal Topic routing doesn't move to different anchorpoint (Read 2923 times)
hans
Jan 24th, 2013 at 1:50am
With the applet, links switched anchorpoint to the nearest, when a node related to the link was moved.
Is there a setting with the same result in js ?
Re: routing doesn't move to different anchorpoint
Reply #1 - Jan 24th, 2013 at 10:42am
You could move the end points from a nodeModified handler:
function onNodeModified(sender, args)
	var node = args.getNode();
	var links = node.getAllLinks();
	Array.forEach(links, function (link)
		link.originConnection.chooseBestAnchorPoint(link.getEndPoint())
		link.setStartPoint(link.originConnection.anchorPointDetails.point);
		link.destinationConnection.chooseBestAnchorPoint(link.getStartPoint())
		link.setEndPoint(link.destinationConnection.anchorPointDetails.point);
	node.getParent().routeAllLinks();
hans
Reply #2 - Jan 24th, 2013 at 3:37pm
I get an error:
link.setEndPoint and link.setEndPoint not defined.
so I used
link.points[0]=link.originConnection.anchorPointDetails.point;
and link.points[link.points.length-1]=...
then it works well
thanks.
Reply #3 - Jan 25th, 2013 at 7:56am
Ok, our developer probably used a bit newer version than yours, that includes these shortcut methods for setting first and last points in links. You can find our latest build here:
https://mindfusion.eu/_beta/jsdiag_start_end.zip
