Normal Topic setting Diagram BackgroundImage Align (Read 1377 times)
Joe
Mar 4th, 2013 at 1:09am
for example:
if (BackGroundImageLayout.ToString() == "Tiled")
Diagram.BackgroundImageAlign = ImageAlign.Tile;
else if (BackGroundImageLayout.ToString() == "Stretch")
Diagram.BackgroundImageAlign = ImageAlign.Stretch;
else if (BackGroundImageLayout.ToString() == "Centered")
Diagram.BackgroundImageAlign = ImageAlign.Center;
if tiled the diagram BackgroundImageAlign is ok,but the Center and Stretch the BackgroundImageAlign does not work.
Re: setting Diagram BackgroundImage Align
Reply #1 - Mar 4th, 2013 at 9:50am
Both Center and Stretch work as expected in my test. Try adding breakpoints to the assignment lines to see if they are ever executed, and verify that BackgroundImageAlign is not reset to Tile later. Also note that BackgroundImageAlign is stored in diagram XML files; if you need it aligned according to some setting in the UI after loading a file, you will have to set the value after each LoadFromXml call.
