Normal Topic intelligent zooming - to a center point (Read 5779 times)
ulthien
Mar 8th, 2013 at 4:37pm
Did anyone already think of having an intelligent zooming in and out that keeps either the selection or the visible nodes in mid of diagram when zooming?
i.e.
if this is the mid point to keep in center:
var mid = MiddlePnt(Selection.Nodes.Count >= 1 ?
Selection.Bounds :
GetContentBounds(false, true));
and
internal Point MiddlePnt(Rect r)
//arithmetic mid
return new Point((r.Right - r.Left)/2, (r.Bottom - r.Top)/2);
how to keep this mid point in center while doing e.g. Mousewheel zoomOut() or zoomIn()? (or over dedicated button functions). NB: zoomIn() and zoomOut() do not have an agrument for specifying the center point.
It seems that the ScrollTo(mid) does not seem to work depending on size of diagram and/or scrollviewer positioning.
This seems to be a function that diagram might always need, so maybe there is a standard method or solution for this?
cheers
Re: intelligent zooming - to a center point
Reply #1 - Mar 11th, 2013 at 7:05am
There is the SetZoomFactor(zoomLevel, centerPoint) method that zooms without changing the screen location of the specified diagram point.
ulthien
Reply #2 - Mar 11th, 2013 at 10:51am
i think neither this function follows the pivot correctly if the diagram.bounds are not fully within the scrollviewer, i.e. probably i will have to enlarge diagram boundaries size prior to pivoting so that there is enough leeway... ?
(investigating)
ulthien
Reply #3 - Mar 11th, 2013 at 3:41pm
Stoyo, did you publish few months ago a variant of MouseWheel handler that zooms in/out of diagram?
do you still have link to it, maybe i am missing some point about scrollviewer vieportwidth or actualwidth...
ulthien
Reply #4 - Mar 11th, 2013 at 5:09pm
i actually foun d& reused your code from and old 2009 post:
        public void SetZoom(double percentage)
            ScrollViewer scrollViewer = (ScrollViewer)Parent;
            var diagramTransform = scrollViewer.TransformToVisual(DocumentPlane);
            // this point should remain centered when zooming in?
            Point scrollViewerCenter = new Point(
                scrollViewer.ActualWidth / 2, scrollViewer.ActualHeight / 2);
            Point weighPt = WeightMidPoint();
            Point diagramPointAtViewCenter = diagramTransform.Transform(weighPt); //weighPt scrollViewerCenter
            ZoomFactor = Math.Max(10, Math.Min(percentage, 200));
            Rect clientAreaSize = new Rect(0, 0, scrollViewer.ActualWidth, scrollViewer.ActualHeight);
            Rect clientAreaDiagSize = ClientToDoc(clientAreaSize);
            // ensure the diagram is always larger than the scrollviewer
            Rect newBounds = GetContentBounds(false, true);
            double diffX = Math.Max(0, clientAreaDiagSize.Width - newBounds.Width);
            double diffY = Math.Max(0, clientAreaDiagSize.Height - newBounds.Height);
            newBounds.Inflate(diffX / 2, diffY / 2);
            Bounds = newBounds;
            // make sure the diagram center is at the scrollviewer center
            ScrollX = diagramPointAtViewCenter.X - clientAreaDiagSize.Width / 2;
            ScrollY = diagramPointAtViewCenter.Y - clientAreaDiagSize.Height / 2;
        //arithmetic mid
            return new Point((r.Right - r.Left)/2 + r.X, (r.Bottom - r.Top)/2 + r.Y);
        //diagram weighted mid (selected or no)
        internal Point WeightMidPoint()
                ClientToDoc(Selection.Bounds) :
                ClientToDoc(GetContentBounds(false, true)));
                //(Selection.Bounds) :
                //(GetContentBounds(false, true)));
            return mid;
so now the behaviour uis better, but still when the user zooms too near, some spiralling happens Tongue
ulthien
Reply #5 - Mar 12th, 2013 at 10:44am
still, the opening point stands that ScrollTo or ScrollX ScrollY cannot scroll to points that are near the diagram border at all.
so you cannot pan programmatically to a node that is near the borders of diagram.
ulthien
Reply #6 - Mar 12th, 2013 at 3:48pm
ok found the problem on the above code:
should be:
Point diagramPointAtViewCenter = weighPt;
and then it pans after the selection well.
solved Cheesy
Reply #7 - Mar 13th, 2013 at 11:44am
Yes, you don't need to transform this point since it's already in diagram coordinates, while scrollViewerCenter from old code is in ScrollViewer's coordinates. It seems a better solution would be to make ScrollViewer accept scroll positions outside the current content range instead of artificially enlarging diagram.Bounds, then it would let you preserve positions near the edges too by simply calling SetZoomFactor. We'll see if we can override the viewer's Arrange method for next release to enable that with a custom ScrollViewer control.
