Normal Topic ContainerChildAdded container zindex issue (Read 2037 times)
j poz
Mar 12th, 2013 at 6:54pm
In situations involving a shapenode moved into a nested container, the ContainerChildAdded event often seems to return a ZIndex of -1 for ContainerChildEventArgs.Container.ZIndex. This means I can't always rely on this method to perform certain zindex corrections I had been hoping to make. Any idea why this would be happening?
j poz
Re: ContainerChildAdded container zindex issue
Reply #1 - Mar 12th, 2013 at 8:45pm
Related strange behavior...
I have a container within a container. The outer container has a zindex of 0, and the inner container has a zindex of 1. When I drag a shapenode inside the inner container, the zindex of the inner container changes to 0.
Are there known issues with containers in containers and the zindex property?
j poz
Reply #2 - Mar 12th, 2013 at 8:50pm
In the previous post, I should say that the args.Container.ZIndex inside of ContainerChildAdded is 0. However, if I am inside of the node modified event and iterate through the nodes, I can find that same container with a ZIndex of 1 as it should be.
It seems like an issue with ContainerChildAdded.
Reply #3 - Mar 13th, 2013 at 6:39am
What kind of Z order corrections do you need to implement? The control changes ZIndex of a container automatically when you drop a node inside it, to ensure the container is drawn behind the child. That happens when child.ZIndex <=container.ZIndex; in that case container.ZIndex is automatically set to child.ZIndex - 1. Since version 6 of the control, ZIndex values no longer correspond to indices within diagram.Items, and ZIndex can have a negative value too.
