Normal Topic Tree Expand/Collapse (Read 5054 times)
newbieDraw
Mar 14th, 2013 at 5:39pm
Hi Stoyo,
I have created custom nodes classes with over-ridden draw methods. The expand/collapse button is not visible, and the diagram does not open/collapse as a tree. I have set all relevant properties to true (Expandable, ExpandButtonPosition, ExpandOnIncoming, etc). Kindly help.
Re: Tree Expand/Collapse
Reply #1 - Mar 14th, 2013 at 5:57pm
You can call DrawManipulators from a Draw override to show the expand/collapse button. It's better to override DrawLocal instead of Draw, or otherwise you will lose support for some other features such as rotation and anchor points.
newbieDraw
Reply #2 - Mar 14th, 2013 at 6:04pm
 public override void Draw(IGraphics graphics, RenderOptions options)
            System.Drawing.Pen blackpen = new System.Drawing.Pen(Color.Black, 0.1f);
            blackpen.DashStyle = System.Drawing.Drawing2D.DashStyle.Solid;
            System.Drawing.Image img = System.Drawing.Image.FromFile(@"C:\temp\segment.png");
            RectangleF rect = new RectangleF(Bounds.X  + Bounds.Width/4, Bounds.Y, Bounds.Width / 2, Bounds.Height / 2);
            graphics.DrawImage(img, rect);
            System.Drawing.Pen graypen = new System.Drawing.Pen(Color.Silver, 0.1f);
            graphics.DrawRectangle(graypen, Bounds.X, Bounds.Y, Bounds.Width, Bounds.Height / 2);
            graphics.DrawRectangle(blackpen, Bounds.X, Bounds.Y + Bounds.Height/2, Bounds.Width, Bounds.Height/2);
            RectangleF stringRect = new RectangleF(Bounds.X, Bounds.Y + Bounds.Height / 2 + Bounds.Height / 16, Bounds.Width, Bounds.Height / 2);
            StringFormat format = new StringFormat();
            format.Alignment = StringAlignment.Center;
            format.LineAlignment = StringAlignment.Center;
            Font font = new Font("Arial", 3, FontStyle.Regular, GraphicsUnit.Pixel);
            System.Drawing.SolidBrush brsh = new System.Drawing.SolidBrush(Color.Black);
            graphics.DrawString(this.Text, font, brsh, stringRect, format);
            this.DrawManipulators(graphics, true);
I have inserted the code above. Can you please provide a sample - how to implement drawmanipulators().
newbieDraw
Reply #3 - Mar 14th, 2013 at 6:27pm
I implemented the code and it works; however, only the links collapse, the nodes remain in place. Please let me know how to fix this.
Reply #4 - Mar 14th, 2013 at 6:37pm
That should work out of the box with latest release. If using older version, add this to the beginning of your draw override:
if (!ShouldRender())
    return;
newbieDraw
Reply #5 - Mar 14th, 2013 at 7:01pm
Thanks, that works perfectly.
newbieDraw
Reply #6 - Aug 14th, 2013 at 11:21pm
Stoyo,
I have developed a new node class; the drawing logic is almost same as in the thread above and the node expand and collapse functions are working (i have to click in some blank space next to the node and it works). However, the plus sign is not visible. Please let me know what might be wrong.
Reply #7 - Aug 15th, 2013 at 5:28am
Are you calling DrawManipulators() for the new class as well?
newbieDraw
Reply #8 - Aug 15th, 2013 at 6:21am
Yes I am calling the drawmanipulators as well. In fact, I imported my previous node classes to this project and they do not show the manipulators either. My previous project was VS2008 .Net 3.5. My current project is VS2012.
Reply #9 - Aug 15th, 2013 at 7:13am
If the VS2008 project showed them, you are probably using a different version of the control in the VS2012 project. Try passing different arguments to DrawManipualtors, and check if there isn't some clip region set at the time you are calling the method.
