Normal Topic A question about Shape property of ShapeNode class (Read 1944 times)
CanadaProgrammer
Apr 14th, 2013 at 11:38pm
I read the help document and there are several different places to show developers how to use Shape proeprty. All code in these smaples can work well. But if I just change a little it can not work well. Such as, there is a smaple in a chapter named Tutorial 7: Custom shape nodes. I copy these sample code and run it without any change, it can work, I show the image below:
and those code is:
node1.Shape = new Shape(
     new ElementTemplate[] {
     new LineTemplate(0, 0, 100, 0),
     new LineTemplate(100, 0, 100, 50),
     new LineTemplate(100, 50, 50, 50),
     new LineTemplate(50, 50, 50, 100),
     new LineTemplate(50, 100, 0, 100),
     new LineTemplate(0, 100, 0, 50)
     FillMode.Winding, "Custom");
But if I change the coordinate of line like below then it can not work:
new LineTemplate(0, 0, 76, 0),
new LineTemplate(76, 0, 76, 22),
new LineTemplate(76, 22, 22, 22),
new LineTemplate(22, 22, 22, 76),
new LineTemplate(22, 76, 0, 76),
new LineTemplate(0, 76, 0, 22)
and the image is below:
look at it, these adjustment handlers do not surround the whole shape exactly, this is the problem. In my case, all lines that consist outline of a shape are vertical or horizontal line, and I need to set any value to start poit and end point of a line. How to solve the problem and do it? Thanks a lot
Re: A question about Shape property of ShapeNode class
Reply #1 - Apr 15th, 2013 at 7:07am
Coordinates in shape definitions are specified as percents of nodes' width and height, i.e. the 76 from your code as % means 3/4 of the node's width. If you need to create shapes from list of arbitrary points, you will have to find the bounding rectangle of the points and map them to a 0-100 coordinate system:
Shape ShapeFromPoints(List<PointF> points, string id)
	float minX = float.MaxValue;
	float minY = float.MaxValue;
	float maxX = float.MinValue;
	float maxY = float.MinValue;
	foreach (var point in points)
		minX = Math.Min(minX, point.X);
		minY = Math.Min(minY, point.Y);
		maxX = Math.Max(maxX, point.X);
		maxY = Math.Max(maxY, point.Y);
	float w = maxX - minX;
	float h = maxY - minY;
	var elements = new ElementTemplate[points.Count];
	for (int i = 0; i < points.Count; i++)
		var p1 = points[i];
		var p2 = points[(i + 1) % points.Count];
		elements[i] = new LineTemplate(
			100 * (p1.X - minX) / w, 100 * (p1.Y - minY) / h,
			100 * (p2.X - minX) / w, 100 * (p2.Y - minY) / h);
	return new Shape(elements, FillMode.Winding, id);
CanadaProgrammer
Reply #2 - Apr 15th, 2013 at 5:30pm
Perfect,thanks.
