I read the help document and there are several different places to show developers how to use Shape proeprty. All code in these smaples can work well. But if I just change a little it can not work well. Such as, there is a smaple in a chapter named Tutorial 7: Custom shape nodes. I copy these sample code and run it without any change, it can work, I show the image below:
and those code is:
node1.Shape = new Shape(
new ElementTemplate[] {
new LineTemplate(0, 0, 100, 0),
new LineTemplate(100, 0, 100, 50),
new LineTemplate(100, 50, 50, 50),
new LineTemplate(50, 50, 50, 100),
new LineTemplate(50, 100, 0, 100),
new LineTemplate(0, 100, 0, 50)
FillMode.Winding, "Custom");
But if I change the coordinate of line like below then it can not work:
new LineTemplate(0, 0, 76, 0),
new LineTemplate(76, 0, 76, 22),
new LineTemplate(76, 22, 22, 22),
new LineTemplate(22, 22, 22, 76),
new LineTemplate(22, 76, 0, 76),
new LineTemplate(0, 76, 0, 22)
and the image is below:
look at it, these adjustment handlers do not surround the whole shape exactly, this is the problem. In my case, all lines that consist outline of a shape are vertical or horizontal line, and I need to set any value to start poit and end point of a line. How to solve the problem and do it? Thanks a lot
