Normal Topic DiagramBase.Clicked Event? (Read 2482 times)
developer
Apr 15th, 2013 at 4:08pm
I'm testing diagram controls to asp.net mvc and I can not launch the Clicked event of the diagram. The code is as follows:
DiagramView view = (Request.Form["diagramView1_PostData"] == null) ? new DiagramView() : DiagramView.FromJson(Request.Form["diagramView1_PostData"]);
Diagram diagram = view.Diagram;
diagram.Clicked += diagram_Clicked;
void diagram_Clicked(object sender, DiagramEventArgs e)
Can someone help me?
Thanks!
Re: DiagramBase.Clicked Event?
Reply #1 - Apr 15th, 2013 at 5:22pm
The events from the Diagram class are used only in the Windows Forms version of the control, which uses the same diagramming.dll assembly. In the ASP.NET MVC version, you can handle events only on the client side by setting NodeClickedScript to the name of a JavaScript function that should be called upon click, or by attaching a handler by calling diagram.addEventListener(Event.nodeClicked, function) on the client side:
diagram.addEventListener(Events.nodeClicked, onNodeClicked);
function onNodeClicked(sender, args)
    alert(args.getNode().getText());
