Normal Topic How to get the bounds of a node at the start of dragging (Read 2777 times)
Kiran B
Apr 20th, 2013 at 8:28am
Is there any property to get the start position (x and y) of a node from which the dragging happened? I need to get this information on the NodeModifyingScript event.
function onNodeModifyingScript(sender, args) {
Kiran B
Re: How to get the bounds of a node at the start of dragging
Reply #1 - Apr 22nd, 2013 at 9:24am
At this time there are only some internal fields you could use to get it:
function onNodeModifying(sender, args)
	var node = args.getNode();
	var diagram = node.getParent();
	var savedState = diagram.interaction.interactionState.originalStates;
	var originalBounds = savedState.get(node).bounds;
Alternatively, you could add your own 'originalBounds' field to nodes and update it from each nodeCreated and nodeModified event raised.
Kiran B
Reply #2 - Apr 22nd, 2013 at 2:02pm
Thanks Stoyan. Thanks a lot for giving insight to the hidden gems.
