Normal Topic Shape move selection position (Read 5047 times)
Kiran B
Apr 29th, 2013 at 9:41am
Currently I can only move the shape by clicking on the center of the shape. Is there any option to move the shape by clicking anywhere in the border of the diagram. I need this coz if i move the shape out of the diagram canvas, sometimes i wont  be able to get the move handle. This time the center will be outside the canvas diagram. So i need this feature. Is there any hack for this?
Kiran B
Re: Shape move selection position
Reply #1 - Apr 29th, 2013 at 12:37pm
You will have to override the handleAtPoint function:
var originalHandleAt = ShapeNode.prototype.handleAtPoint;
ShapeNode.prototype.handleAtPoint = function (point)
	var handle = originalHandleAt.apply(this, [point]);
	if (handle != null)
		return handle;
	if (this.containsPoint(point))
		return { item: this, index: 8 };
	return null;
Kiran B
Reply #2 - May 1st, 2013 at 8:17am
I fact we have to give the code like below, otherwise error will be thrown saying that ShapeNode is null.
var originalHandleAt = MindFusion.Diagramming.ShapeNode.prototype.handleAtPoint;
        MindFusion.Diagramming.ShapeNode.prototype.handleAtPoint = function (point) {
            if (handle != null)
                return handle;
            return null;
But after i put this code nothing happens. Still the move handle is at the center. Could you please check this.
Also could you please tell me the expected behaviour? Also what is the below line doing?
Kiran B
Reply #3 - May 1st, 2013 at 9:06am
Yes, I had a var ShapeNode = MindFusion.Diagramming.ShapeNode; in the test page, you can use that too to avoid repeating the namespace. That replaces only the ShapeNode's method, since you are also using containers, you might need to do the same for ContainerNode class.
Kiran B
Reply #4 - May 1st, 2013 at 9:20am
you didn't answer my second question
Kiran B
Reply #5 - May 1st, 2013 at 11:55am
That code lets you move the node by dragging from anywhere within the shape. It does not draw the move handle at a different position.
Kiran B
Reply #6 - May 1st, 2013 at 6:50pm
Hi Stoyan,
Sorry i was trying with container node that's why nothing was heppening for me. I replaced ShapeNode with ContainerNode and its working great. Its even drawing the move handle. Thanks.
Kiran B
Reply #7 - May 10th, 2013 at 6:24am
I have just noticed some refresh lag in my test app while drawing nodes interactively due to above function. Use this version of the code instead:
	if (handle != null)
		return handle;
	if (!this.selected)
		return null;
	var bounds = this.getRotatedBounds();
	if (!bounds.containsPoint(point))
		return null;
	if (MindFusion.Diagramming.Utils.pointInPolygon(point, this.getOutline()))
	return null;
Kiran B
Reply #8 - May 10th, 2013 at 8:14am
Hi Stoyan,
Thanks a lot for these sort of follow ups. Really great. I will update.
Kiran B
