Normal Topic How to Restrict overlapping of shapes? (Read 1739 times)
Kiran B
May 10th, 2013 at 6:28pm
How can i restrict overlapping of shapes? If i add a shape to a container that should happen. In all other cases avoid overlapping of shapes. Same is applicable for children inside the container.
Is there a fix for this?
Kiran B
Re: How to Restrict overlapping of shapes?
Reply #1 - May 13th, 2013 at 8:43am
There is a static DiagramNode.nodesIntersect(node1, node2) method you could use to check if a pair of nodes intersect. You can call it from nodeModifying and nodeCreating handlers to check if args.getNode() intersects with any other node from diagram.nodes, and call args.setCancel(true) if it does.
