Normal Topic Minimum node size for container (Read 3056 times)
Kiran B
May 10th, 2013 at 7:13am
Hi Stoyan,
We are facing an issue with Container node size.
I am adding container node from the nodelistview and reduce its size below 50,40 (which is the minimum size for the container node). But when it reaches the server side it defaults to the size 50,40.
I tried setting the below code but no luck.
  _diagramView.Diagram.MinimumNodeSize = new SizeF(10, 10); in the server side.
Is there any client side method to override the size of the container?
I am saving the diagram xml in database for persisting. Coz of this issue reducing the size of container and saving is not giving the desired effect.
Is there is workaround for this?
Kiran B
Re: Minimum node size for container
Reply #1 - May 10th, 2013 at 12:48pm
For the time being, set diagram.ContainerMinimumSize to a small value before loading from Json on server. We'll implement it in JavaScript too in one of the next releases.
Kiran B
Reply #2 - May 10th, 2013 at 2:05pm
hi Stoyan,
Ok. But which is the right place to set it? I am already setting this in the action method. But no luck.
Could you please provide some code for this?
Kiran B
Reply #3 - May 13th, 2013 at 9:57am
Try the version from https://mindfusion.eu/_beta/mvcdiag_ctrbounds.zip, it should deserialize container's Bounds regardless of its MinSize value.
