Normal Topic Questions about ruler and Node Center handle, etc. (Read 3764 times)
Kyle Chen
Apr 30th, 2013 at 3:20pm
Hi Stoyan,
I need you help again -
1. Is there any way to add a tooltip to diagram ruler?
2. For center handle of a node - I'm using EasyMove for HandlesStype.
  1) Is there any way to make the center handle also able to move the node?
  2) Any way to make the center handle more observable? Like change to a blue color other than white or change size/shape
  3) Any way to make a Locked node display a small lock icon at the corner and make a solid border around it like HatchFrame(but hatchframe is too ugly) Tongue
Thank you!
Kyle
Re: Questions about ruler and Node Center handle, etc.
Reply #1 - May 1st, 2013 at 7:49am
1. You could show a ToolTip control in response to ruler's mouse hover events:
private void Form1_Load(object sender, System.EventArgs e)
	var hScale = ruler.Controls[1].Controls[0];
	var vScale = ruler.Controls[2].Controls[0].Controls[0];
	hScale.MouseHover += OnRulerMouseHover;
	vScale.MouseHover += OnRulerMouseHover;
ToolTip rulerTooltip = new ToolTip();
void OnRulerMouseHover(object sender, EventArgs e)
	var tooltipPos = ruler.PointToClient(MousePosition);
	tooltipPos.X += 16;
	var diagPos = diagramView.ClientToDoc(
		diagramView.PointToClient(MousePosition));
	rulerTooltip.Show("pos: " + diagPos, ruler, tooltipPos, 2000);
Reply #2 - May 1st, 2013 at 8:07am
2. You could set HandlesStyle to Custom and handle Draw/HitTest events:
void OnDrawAdjustmentHandles(object sender, MindFusion.Diagramming.DrawItemEventArgs e)
	var node = (DiagramNode)e.Item;
	var style = node == diagram.ActiveItem ?
		diagram.ActiveItemHandlesStyle :
		diagram.SelectedItemHandlesStyle;
	InternalUtils.DrawSelHandles(
		e.Graphics,
		style,
		diagram.DisabledHandlesStyle,
		node.Bounds,
		node.RotationAngle,
		node.EnabledHandles,
		true,
		HandlesStyle.SquareHandles,
		diagram.AdjustmentHandlesSize);
	var c = node.GetCenter();
	var r = new RectangleF(c.X, c.Y, 0, 0);
	r.Inflate(2.5f, 2.5f);
	e.Graphics.FillEllipse(Brushes.Blue, r);
	var p = (System.Drawing.Pen)Pens.Black.Clone();
	p.Width = 0;
	e.Graphics.DrawEllipse(p, r);
	p.Dispose();
void OnHitTestAdjustmentHandles(object sender, HitTestEventArgs e)
	if (e.Item.ContainsPoint(e.MousePosition))
		e.HitResult = 8;
Reply #3 - May 1st, 2013 at 8:14am
3. Set node.CustomDraw = Additional2 and handle DrawNode event:
private void diagram_DrawNode(object sender, DrawNodeEventArgs e)
	if (e.Node.Locked)
		// draw icon
		e.Graphics.DrawImage(lockImage, 1, 1);
		// draw border
		e.Graphics.DrawRectangle(Pens.Black, e.Bounds);
Kyle Chen
Reply #4 - May 3rd, 2013 at 7:26pm
Hi Stoyan,
First thank you for so detailed code samples. They work well for all my questions except a little bug for Moving node.
When a node is small(like 10x8 pixels) and all the handles will stacked together. When this happens, I cannot move it any more. Whenever I drag it one or two pixels away, the mouse cursor will change from "move" to "cancel". And when mouse is released the node back to original place.
Can you look into this? Thanks.
Stoyo wrote on May 1st, 2013 at 8:07am:
		e.HitResult = 8;
Reply #5 - May 6th, 2013 at 6:08am
Set Diagram.MinimumNodeSize to a size smaller than any nodes you create programmatically.
Kyle Chen
Reply #6 - May 6th, 2013 at 3:49pm
Thank you Stoyan. That does help!! Cool
