Normal Topic Node Movement In Pan Mode (Read 1485 times)
priyanka
May 2nd, 2013 at 10:51am
I have set diagram.Behavior = Behavior. Pan.
My requirement is :
     1. Need to move nodes while in Pan mode
     2. Need to create links while in Pan mode.
How do I achieve this.
Please let know.
Priyanka
Re: Node Movement In Pan Mode
Reply #1 - May 2nd, 2013 at 11:30am
You could switch Behavior value between Pan and DrawLinks from a MouseMove handler, depending on what's under the mouse pointer.
Alternatively, you could create a custom behavior class that's a composite of a PanBehavior and DrawLinksBehavior objects, and then delegate all Mouse* methods to one of the objects, depending on what was under the mouse pointer in MouseDown.
