Normal Topic Copy and Paste Not Working With Custom Diagram Class (Read 1660 times)
lrhudson
Aug 21st, 2013 at 10:29am
Hi
I am having great problems trying to implement a copy and paste feature for a WPF diagramming custom object.
    [Serializable]
    internal class TranslateFunctionNode : FunctionNode
        public override DiagramItem Clone(bool clipboard)
            DiagramItem item = base.Clone(clipboard);
            return item;
            //return base.Clone(clipboard);
protected override void SaveToXml(System.Xml.XmlElement xmlElement, XmlPersistContext context)
            base.SaveToXml(xmlElement, context);
            context.WriteString(FunctionName, ElementFunctionName, xmlElement);
            context.WriteInt(TemplateID, ElementTemplateID, xmlElement);
            context.WriteString(TemplateName, ElementTemplateName, xmlElement);
        protected override void LoadFromXml(System.Xml.XmlElement xmlElement, XmlPersistContext context)
            base.LoadFromXml(xmlElement, context);
            FunctionName = context.ReadString(ElementFunctionName, xmlElement);
            TemplateID = context.ReadInt(ElementTemplateID, xmlElement);
            TemplateName = context.ReadString(ElementTemplateName, xmlElement);
            Description = CreateDescription(TemplateID, TemplateName);
    [Serializable]
    public abstract class FunctionNode : TemplatedNode
I have tried calling CopySelection and PasteSelection and CopyToClipboard/PasteFromClipboard methods but none seem to work.  No exceptions are raised but the clone method returns null and the SaveToXML method is not called on copy.
I have marked all classes as serializable and have called:
Diagram.RegisterItemClass(typeof(FunctionNode), "FunctionNode", 0);
            Diagram.RegisterItemClass(typeof(TranslateFunctionNode), "TranslationFunctionNode", 0);
in the Xaml.cs constructor.
Any ideas?  Finding this very frustrating!!!
Lee
Re: Copy and Paste Not Working With Custom Diagram Class
Reply #1 - Aug 21st, 2013 at 10:43am
TranslateFunctionNode.Clone() should return a TranslateFunctionNode instance, and not one of the base class. That should happen automatically if your class has a copy constructor: Clone calls it automatically via reflection. So you should either define a copy constructor, or create a TranslateFunctionNode in the Clone override and copy its properties from current object.
