Normal Topic Disable inline edit for a node (Read 2783 times)
Kiran B
May 8th, 2013 at 1:02pm
How to disable inline edit for a shape based on some logic.
Kiran B
Re: Disable inline edit for a node
Reply #1 - May 8th, 2013 at 1:54pm
You could set DiagramView.AllowInplaceEdit to false to prevent it for all nodes, and with this version of the script call diagram.beginEdit(args.getNode()) from a nodeDoubleClicked event handler:
http://mindfusion.eu/Forum/YaBB.pl?num=1367424264
With that version you will also no longer need the ContainerNode replacements for resizeToFit, startDrag and cancelDrag.
Alternatively, you could replace the Diagram.beginEdit(item,point) function with your own version that simply returns for some nodes.
mandz
Reply #2 - May 9th, 2013 at 12:52am
Thanks, this helped me too.  I used for Javascript:
Code (Javascript)
diagram.setAllowInplaceEdit(true);
