Normal Topic User data is 32-bit? (Read 5727 times)
sbailey
May 10th, 2013 at 7:25pm
I've been using user data on tables and boxes to store pointers. Unfortunately, this doesn't work so well in x64. Is there something I'm missing or is this value still just a 32-bit long?
I've come up with a workaround, but I'm curious.
Editor Programmer&&Bethesda Softworks
Re: User data is 32-bit?
Reply #1 - May 11th, 2013 at 8:08am
The 64-bit version is compiled from the same source code and IDL interface definition, so the LONG UserData property is still 32bit. You can store 64-bit values in VariantTag, using the LONGLONG llVal or any pointer field of the VARIANT struct.
sbailey
Reply #2 - May 11th, 2013 at 1:18pm
Quite a bit -- thanks!
sbailey
Reply #3 - May 17th, 2013 at 3:20pm
I'll just ask here instead of making a new topic. I could implement this myself via event handling but don't want to if I don't have to Smiley -- is there any way to have a box be dragged no matter where you clicked it? The center handle doesn't work well for the user when a box is very wide.
Reply #4 - May 17th, 2013 at 3:27pm
Try setting SelStyle = sstEasyMove.
sbailey
Reply #5 - May 17th, 2013 at 3:31pm
Missed that in the docs. Thanks!
