Hot Topic (More than 10 Replies) Arrow tooltips (Read 10686 times)
sbailey
Arrow tooltips
Jun 3rd, 2013 at 4:35pm
When creating my flowchart, I'm calling PutShowToolTips( TRUE ) and also, for good measure, calling PutToolTipAutoPop( 5000 ) and PutToolTipDelay( 1000 ). I'm setting tooltips on my arrows with PutToolTip( ), but I see nothing when I hover over them.
Anything I'm missing?
Editor Programmer&&Bethesda Softworks
Re: Arrow tooltips
Reply #1 - Jun 3rd, 2013 at 5:28pm
If there are any nodes behind these arrows, try setting HitTestPriority = ZOrder.
sbailey
Re: Arrow tooltips
Reply #2 - Jun 4th, 2013 at 11:26am
Definitely key -- thanks -- but not all I'm lacking apparently. Let me play around with it and see if I can figure it out.
On the subject of arrows, is there any way that one can combine bhCreateArrow with bhPanAndModify? I need to be able to move objects around and scroll the flowchart by dragging it, but I also need to be able to create arrows.
Re: Arrow tooltips
Reply #3 - Jun 4th, 2013 at 11:34am
Try the following:
Private Sub Form_Load()
    fcx.FireMouseMove = True
End Sub
Private Sub fcx_MouseMove(ByVal docX As Long, ByVal docY As Long)
    Dim b As box
    Set b = fcx.GetBoxAt(docX, docY)
    If b Is Nothing Then
        fcx.Behavior = bhPanAndModify
    Else
        fcx.Behavior = bhFlowChart
    End If
End Sub
sbailey
Re: Arrow tooltips
Reply #4 - Jun 4th, 2013 at 11:37am
Oh, that makes sense! Thanks.
sbailey
Re: Arrow tooltips
Reply #5 - Jun 6th, 2013 at 7:39pm
I just cannot get tooltips to show up at all. I tried putting one on a box that was definitely the only thing at a certain position. Nothing. There must be something that needs to be done besides calling PutShowToolTips( TRUE ).
Note: I'm using Wn32 C++.
Re: Arrow tooltips
Reply #6 - Jun 7th, 2013 at 6:49am
It seems a few years ago you managed to show them by enabling ShowToolTips at a later point, try that again:
http://mindfusion.eu/Forum/YaBB.pl?num=1244143856/2#2
ShowToolTips associates a Win32 tooltip control with the flowchart window, but some MFC or ATL initialization code in your application might be overriding it, so try setting ShowToolTips as late as possible.
sbailey
Re: Arrow tooltips
Reply #7 - Jun 7th, 2013 at 12:59pm
Sadly, that doesn't seem to be helping with the arrow tooltips. I've tried turning them on right before setting the tooltip text and also calling ShowToolTips( FALSE ) and then ( TRUE ) even on MouseMove. But you're right that something might just be incompatible. I can easily do fake tooltips.
Re: Arrow tooltips
Reply #8 - Jun 7th, 2013 at 5:15pm
Do you mean they work for nodes now but not for arrows? Have you set the HitTestPriority property to ZOrder?
sbailey
Re: Arrow tooltips
Reply #9 - Jun 10th, 2013 at 2:02pm
Yes, I set that property. Currently, they neither work for arrows nor tables.
I made my own tooltip box. However, interestingly, in some very very large flowcharts (I've got one that's 65,000 units wide and has 370 nodes), GetArrowAt( x, y ) doesn't seem to work. Neither does GetTableAt( x, y ). I've made sure that all of my z indices are set correctly.
Ideally, I'd like to get your tooltips working; however, failing that, I'd like to figure out why GetTableAt and GetArrowAt are returning null.
Re: Arrow tooltips
Reply #10 - Jun 10th, 2013 at 6:22pm
I can't see a problem with items at large coordinates, they still show tooltips in my test:
fcx.SetDocSize 0, 0, 100000, 100000
Dim t1 As table
Dim t2 As table
Dim a As arrow
Set t1 = fcx.CreateTable(99700, 99900, 30, 30)
t1.ToolTip = "test1"
Set t2 = fcx.CreateTable(99900, 99950, 30, 30)
t2.ToolTip = "test2"
Set a = fcx.CreateRelation(t1, 0, t2, 0)
a.ToolTip = "test3"
fcx.ShowToolTips = True
Please attach a file where tooltips don't work for you.
Check if you aren't storing mouse position in signed short integer variables, they will stop working for values larger than 32K.
sbailey
Re: Arrow tooltips
Reply #11 - Jun 10th, 2013 at 6:49pm
actually i'm using unsigned shorts (maxima of 65535) but that's probably still what's happening -- my width of 65,000 might really be 66,000 and it might be failing on the edge. right. that's embarrassing.
