Hot Topic (More than 10 Replies) Export to SVG and PDF not working properly (Read 6868 times)
Ton Trommelen
Jun 10th, 2013 at 10:14am
when I export a diagram to SVG and/or PDF the output is not as it should be;
with SVG the size of the nodes in the diagram is to big and with PDF I loose text information of the nodes.
....see attachments....
What can be causing this and how to fix it?
Re: Export to SVG and PDF not working properly
Reply #1 - Jun 10th, 2013 at 11:59am
Please attach the diagram saved as XML file.
Ton Trommelen
Reply #2 - Jun 10th, 2013 at 2:44pm
...here is the XML file...
Note that I'm using a custom node class.....can this be the problem?
Reply #3 - Jun 10th, 2013 at 5:11pm
Could you post your drawing code then? Please also implement the XML serialization methods and attach the file again, so that we can try it with your images and texts, for example:
protected override void SaveToXml(XmlElement xmlElement, XmlPersistContext context)
    base.SaveToXml(xmlElement, context);
    context.WriteImage(icon, "Icon", xmlElement);
    context.WriteString(label, "Label", xmlElement);
protected override void LoadFromXml(XmlElement xmlElement, XmlPersistContext context)
    base.LoadFromXml(xmlElement, context);
    icon = context.ReadImage("Icon", xmlElement);
    label = context.ReadString("Label", xmlElement);
We might have not implemented correctly for SVG/PDF IGraphics method overloads that are not used by standard node types, so perhaps you can get better results by using a different Draw* overload, e.g. DrawImage(RectangleF) instead of DrawImage(x,y).
Ton Trommelen
Reply #4 - Jun 10th, 2013 at 9:31pm
Here is the node class I use....
IconNode.zip (Attachment deleted)
Reply #5 - Jun 11th, 2013 at 7:13am
This version of Draw should work fine when exporting:
	Public Overrides Sub Draw(ByVal graphics As IGraphics, ByVal options As RenderOptions)
		Dim iconSizePixels As Rectangle = New Rectangle(0, 0, imgIcon.Width, imgIcon.Height)
		Dim imageSize As RectangleF = MindFusion.Utilities.DeviceToDoc(graphics, iconSizePixels)
		' Draw the icon center at the top
		Dim lPoint As System.Drawing.PointF
		lPoint.X = Bounds.X + Bounds.Width / 2 - imageSize.Width / 2
		lPoint.Y = Bounds.Y
		Dim r As RectangleF
		r = New RectangleF( _
		 Form1.diagView.ClientToDoc(Form1.diagView.DocToClient(lPoint)), imageSize.Size)
		graphics.DrawImage(imgIcon, r)
		'Draw the label at the bottom
		Dim labelBounds As RectangleF = RectangleF.FromLTRB(Bounds.X, Bounds.Y + imageSize.Height, Bounds.Right, Bounds.Bottom)
		labelBounds.Inflate(10, 0)
		graphics.DrawString(title, Font, New System.Drawing.SolidBrush(ColorTranslator.FromHtml(tcolor)), labelBounds, format)
	End Sub
Ton Trommelen
Reply #6 - Jun 11th, 2013 at 8:21am
Hi!
....your new code works much better....but it's not quite perfect yet; I still loose the text on the second line. See attachment;
(FTPSupload) should be:
(FTPSupload)
Test upload
...any chance this can be fixed as well?
Reply #7 - Jun 11th, 2013 at 12:10pm
The text seems to clip to the specified rectangle both in SVG and PDF, so try making the rectangle large enough:
Dim labelSize = Parent.MeasureString( _
	title, EffectiveFont, Integer.MaxValue, format)
Dim labelBounds As RectangleF = New RectangleF( _
	Bounds.X, Bounds.Y + imageSize.Height, labelSize.Width, labelSize.Height)
labelBounds.Inflate(5, 5)
graphics.DrawString(title, _
Ton Trommelen
Reply #8 - Jun 11th, 2013 at 3:01pm
I changed line: labelBounds.Inflate(10, 0)
to: labelBounds.Inflate(5, 5)
That did the trick.
Thanks a lot for the help!!!!
Ton Trommelen
Reply #9 - Jun 11th, 2013 at 3:25pm
I cheered a little to soon; although the diagram and the exports are now ok.....the overview is not! This now contains big icons....see attachments.
Reply #10 - Jun 11th, 2013 at 4:07pm
It probably happens because the image size is converted from pixels using DiagramView.DeviceToDoc, which calculates it using a different scale than the one set for the Overview. You could keep your old image drawing code that does not specify size and run it inside an "if typeof (graphics) is GdiGraphics" block, and put the current code in an else statement for SvgGraphics and PdfGraphics.
Ton Trommelen
Reply #11 - Jun 11th, 2013 at 8:09pm
That did the trick!
Thanks again!!!!
Ton Trommelen
Reply #12 - Jun 12th, 2013 at 5:51pm
Now that I'm more into this Draw() stuff;
the overview is still not as good as it can be I think....see attachments.
Is there any way to improve the overview using my custom class?
Thanks for all your help!
Reply #13 - Jun 13th, 2013 at 8:45am
The problem is that when converting image size from pixels for centering the image and for finding label offset, you need only its size in millimeters, without considering the scale applied on the graphics, while the code above also applies the scale transform.  Try this version instead:
	' convert to millimeters without considering scale
	Dim g As GdiGraphics
	g = Parent.CreateMeasureGraphics()
	g.ResetTransform()
	Dim imageSize As RectangleF = Utilities.DeviceToDoc(g, iconSizePixels)
	g.Dispose()
	lPoint.Y = Bounds.Y
	Dim r As RectangleF
End Sub
With the size only converted to millimeters, you also don't need a separate case for Svg and PdfGraphics:
Ton Trommelen
Reply #14 - Jun 17th, 2013 at 8:52am
Works great! Thanks!!!!!
