Normal Topic No aero effect on my custom nodes (Read 1651 times)
Rennie
Jun 14th, 2013 at 5:53am
I'm using the aero effect on my composite nodes, and that's working fine. Now I'm trying to also use it for some of my custom nodes that are simply derived from DiagramNode and typically override the Draw() and DrawShadow() methods, and it doesn't work.
Is there some sample program or information indicating what a custom node needs to implement in order to allow the aero effect (or some other effect?) to work?
Thanks.
Re: No aero effect on my custom nodes
Reply #1 - Jun 14th, 2013 at 7:41am
That's not supported at this time. You could derive from ShapeNode and call base.Draw to render the background effects, and then add any extra drawing code you need on top. Alternatively keep something like 'ShapeNode effectsRenderer' object as member of the form (not necessarily in the diagram), change its Bounds and call its Draw method when drawing custom nodes.
Rennie
Reply #2 - Jun 15th, 2013 at 2:24am
Thanks for your many and helpful and patient replies. I'll see what I can figure out ...
