Normal Topic Cannot scroll to bottom of diagram (Read 1430 times)
DavidZ
Jun 19th, 2013 at 9:32am
For some diagrams I am unable to scroll to the bottom of the diagram. It is almost as though the scroll size does not update as nodes are added. Is there a way to ensure that I can scroll through the whole diagram?
David
Re: Cannot scroll to bottom of diagram
Reply #1 - Jun 19th, 2013 at 10:05am
The scroll range depends only on Diagram.Bounds value, which is not updated automatically by layout algorithms. After layout.Arrange, you could also call diagram.ResizeToFitItems to make Bounds large enough to fit all items. Alternatively, set diagram.Bounds to the union of its current value and diagram.GetContentBounds() result, to allow the diagram grow but not become smaller.
DavidZ
Reply #2 - Jun 19th, 2013 at 2:46pm
Perfect. Thank you
David
