Normal Topic Links entering or exiting from a fixed position (Read 1787 times)
DavidZ
Jun 20th, 2013 at 9:53am
I was wondering if there was a way to force a link to always enter a node from the top.
I am currently using the flowchart layout but my end node is a wide ellipse because there may be many links that go to it. However in one permutation there are only two links going to it but they both go to the side. I was wondering if there was a way to force them to enter from the top.
David
Re: Links entering or exiting from a fixed position
Reply #1 - Jun 20th, 2013 at 12:31pm
Run this after applying FlowchartLayout:
if (endNode.IncomingLinks.Count == 2)
	var c = endNode.GetCenter();
	var r = endNode.Bounds;
	foreach (var link in endNode.IncomingLinks)
		if (Math.Abs(link.EndPoint.Y - r.Top) < 0.1f)
			continue;
		var nl = link.ControlPoints[link.ControlPoints.Count - 2];
		nl.Y = r.Top - 10;
		link.ControlPoints[link.ControlPoints.Count - 2] = nl;
		link.EndPoint = new PointF(c.X, nl.Y);
		link.ControlPoints.Add(new PointF(c.X, r.Top));
		link.UpdateFromPoints(false, true);
