Normal Topic How to get position of node? (Read 6231 times)
kim
Jul 11th, 2013 at 7:37am
Hello, there.
I'm trying to create a tree graph using FlowChartX.
I want to have one function about node rearrangement.
To be specific, after I randomly move each node by drag & drop, I want rearrange them according to their position (i.e. Y-axis)
How can I get the position of each node?
Or do you have any idea for my work?
Re: How to get position of node?
Reply #1 - Jul 11th, 2013 at 10:01am
After moving nodes, you can run TreeLayout with its PreserveOrder property set to true to sort the arranged nodes by their initial positions.
kim
Reply #2 - Jul 12th, 2013 at 12:11am
Firstly, thank you for your reply.
However, What I want to do is rearranging node by their current positions NOT initial position. Can you help me?
Reply #3 - Jul 12th, 2013 at 7:08am
I meant initial positions for the layout object at the time you run it, which are the current ones. E.g. this ObjectModified handler lets you rearrange nodes in a tree layer:
Private Sub fcx_ObjectModified(ByVal obj As Object, ByVal selHandle As Long)
    Dim layout As New TreeLayout
    layout.Direction = tldLeftToRight
    layout.PreserveOrder = True
    fcx.ArrangeDiagram layout
End Sub
kim
Reply #4 - Jul 12th, 2013 at 8:36am
OK, I got it. I really thank you for your help.  Wink
B.R. H.Kim
