Normal Topic Gap between Links (Read 1358 times)
Dirk Frischalowski
Gap between Links
Jul 12th, 2013 at 12:13pm
Hallo,
we use the RouteLinks=true - Property on the Diagram control for automatic link routing. When a user draws 2 Links between the same 2 Nodes the Links are layouted one above the other. We want a small gap between the Links to visually show the user that there are 2 connections between the nodes (or more).
Can we do this with setting some properties or do we have to programm something for that functionality?
We want this gap also for all incoming and outgoing links on one node.
Thanks for help!
regards
Dirk
Re: Gap between Links
Reply #1 - Jul 13th, 2013 at 11:32am
Try calling ReassignAnchorPoints from LinkCreated handler:
private void diagram_LinkCreated(object sender, LinkEventArgs e)
	var link = e.Link;
	link.Origin.ReassignAnchorPoints();
	link.Destination.ReassignAnchorPoints();
Or see some alternative methods here:
http://mindfusion.eu/Forum/YaBB.pl?num=1227111424/1#1
http://mindfusion.eu/Forum/YaBB.pl?num=1266388133/8#8
