Normal Topic floating node (Read 1960 times)
chris g
floating node
Jul 17th, 2013 at 11:00am
I'm using flowchart.net for windows forms and am trying to keep a node centered in the view (only horizontally.) The view never has horizontal scroll-bars when I'm trying to do this.
The diagram measure units are in pixels, the diagram autoresize property is set to none. The problem is that when I set the bounds, it moves too far to the right. I'm almost certainly doing something silly, I'd be grateful if anyone could give me any pointers.
_node is the node I would like to center in the view and this code is called from the resize event handler on the diagram view.
RectangleF NodeBounds = _node.Bounds;
RectangleF DocDiagramBounds = View.ClientToDoc(new Rectangle(0, 0, View.Width, 0));
DocDiagramBounds.Height = Diagram.Bounds.Height;
Diagram.Bounds = DocDiagramBounds;
NodeBounds.X = (((float)Diagram.Bounds.Width) / 2.0f) - (_node.Bounds.Width / 2.0f);
 _node.SetBounds(NodeBounds, true, true);
Thanks.
Chris.
Re: floating node
Reply #1 - Jul 17th, 2013 at 11:20am
Your code works correctly in my test project. However you might get unexpected results if the view's ZoomFactor is different from 100 or the scroll position is different from 0 at the time when you call ClientToDoc. Add a breakpoint at that line and verify these properties' values when the debugger hits it.
Also check other references to _node; there might be another event handler moving it to the right later on (e.g. note that view_Resize is raised once before Form_Load).
chris g
Re: floating node
Reply #2 - Jul 17th, 2013 at 11:28am
Thankyou for an extremely quick response. I will check out your suggestions.
chris g
Re: floating node
Reply #3 - Jul 17th, 2013 at 11:59am
Thanks, with your help I was able to isolate the problem. It now looks great Smiley
