Normal Topic Floating anchor point on a container (Read 2526 times)
j poz
Jul 15th, 2013 at 2:23pm
I am trying to place an anchor point about 25 pixels above the middle of a container and am running into some issues.
When I try to do something like this..
AnchorPoint ap = new AnchorPoint(50, -10, true, false);
It does place the anchor point above the container, however it moves around as the container expands in size or is collapsed/expanded, because it is "negative 10 percent" of the height which on a container changes. I need it to stay in the same location regardless of the size of the container.
Do you have any ideas for how I might accomplish this?
Re: Floating anchor point on a container
Reply #1 - Jul 16th, 2013 at 6:58am
We'll add some enum property for next release to specify whether anchor positions are specified in percents or fixed coordinates. If you have the source code, you can edit the AnchorPoint.GetPosition(Rect nodeRect) method to return a fixed position.
Reply #2 - Jul 17th, 2013 at 9:15am
This version adds XUnit and YUnit properties to AnchorPoint:
https://mindfusion.eu/_beta/fcnet_apunit.zip
Their default value is Percentage. Set it to Fixed for the Y coordinate to make it stay at a fixed distance from the top:
AnchorPoint ap = new AnchorPoint(50, -10, true, false) { YUnit = AnchorUnitType.Fixed} );
j poz
Reply #3 - Jul 18th, 2013 at 2:24pm
Is it possible to get the source code for this?
Reply #4 - Jul 19th, 2013 at 9:39am
Yes, you can request it at support@mindfusion.eu.
