Normal Topic JDiagram 4.0.2 has been released! (Read 1947 times)
Aug 20th, 2013 at 7:27pm
We have released version 4.0.2 of JDiagram. It contains various customer-requested features and fixes several bugs:
ContainerNode improvements
~ child nodes are now drawn by their containers; when containers overlap, the children of a lower container cannot appear in front of the upper container anymore;
~ the ClipChildren property specifies whether to clip child items to container’s boundaries;
~ the ZIndex property  no longer changes automatically when dropping nodes into a container;
~ the Visible property of child items no longer changes when folding or unfolding containers; this lets you keep invisible items inside containers;
~ when selection including a container and its child node is dropped into another container, the child node now remains in its original container;
~ the ScrollZoneSize property of DiagramView can be used to specify the size of the area near the control edges that starts auto-scrolling.
~ improved placement of link labels along shorter link segments.
The arrangeLinkLabels method rearranges link labels whose AutoArrange flag is set.
~ DiagramLink.intersects checks whether two links intersect.
~ the hitTest method determines whether a diagram item or any of its child items contain the specified point.
~ overriding hitTestHandle in a derived item type lets you implement custom adjustment handle testing for the type.
~ the getFlatItemList returns a list of all TreeViewNode items.
~ the GridOffsetX and GridOffsetY properties let you change the origin of the alignment grid.
~ fixed selection handles repaint bug http://mindfusion.eu/Forum/YaBB.pl?num=1370470277
~ fixed cascading link auto-orientation bug http://mindfusion.eu/Forum/YaBB.pl?num=1372994107
https://www.mindfusion.eu/JDiagramTrial.zip
