Normal Topic Need help on DelKeyAction and place a node on Diagram at specified location (Read 4429 times)
esri_test
Aug 21st, 2013 at 4:22pm
I am doing similar thing as FlowCharter example.
I need help in two things:
1. I tried to use "delete" key on keyboard to delete a selected node. It works in the example, but doesn't work in mine. What I am missing? I tried the same thing as FlowChater for context menu delete, that works.
2. I tried to place nodes at certain coordinate on the diagram because I have comment box placed close to certain node, so I need ability to place node at exact location on diagram. I am reading those X, Y in from XML. I am trying to place on diagram by diagram.factory.createshapenode(point, size). This doesn't work. It only controls the bounds of the node. Which method controls the node location in the diagram?
Re: Need help on DelKeyAction and place a node on Diagram at specified location
Reply #1 - Aug 21st, 2013 at 4:43pm
1. Have you set Focusable="False" for the parent ScrollViewer? Otherwise it acquires the keyboard focus and stops key events from reaching the diagram.
2. The point argument specifies the location of node's top-left corner, and this work fine in my test:
diagram.Factory.CreateShapeNode(new Point(50, 50), new Size(50, 50));
If you are getting wrong location, check if the point has been initialized correctly, and if you aren't moving the node later.
esri_test
Reply #2 - Aug 21st, 2013 at 7:31pm
Thank you, Stoyan!
1st one works!
2nd one, I tried things like:
double yloc =0;
for (var node in nodes)
yloc += 50;
Point pt = new Point(50, yloc);
var diagramnode = diagram.Factory.CreateShapeNode(pt, new Size(120, 40));
I thought the nodes should line up from top to bottom since y increases vertically, but what I got is a line from left to right horizontally. I switched x, y, I still got the same thing. For now, no link involved in. Any ideas what I did wrong?
Reply #3 - Aug 21st, 2013 at 7:39pm
Your code creates nodes arranged in a vertical column for me. Check if something else doesn't move the nodes later; e.g. running layout algorithms will place the nodes in a horizontal line by default when there are no links between them.
esri_test
Reply #4 - Aug 21st, 2013 at 8:59pm
Thank you, Stoyan!
Now I understand what you mean by "Check if something else doesn't move the nodes later". I used LayerLayout.arrange(diagram).
esri_test
Reply #5 - Aug 22nd, 2013 at 5:16pm
I have new issues with FlowLayout to arrange the nodes and links.
By using "FlowLayout" the nodes are placed correctly at specified location, but links do not look clean and neat. I compared with "FlowchartLayout" arrange way, the links are what I want, but the nodes are not placed at specified location. How can I borrow "FlowchartLayout" link rules to apply to "FlowLayout" so I can get the diagram with node at specified location and links are clean and neat? I don't know how to code this... please direct to me to the class and methods I need...
Reply #6 - Aug 22nd, 2013 at 5:54pm
You cannot reuse FlowchartLayout link arrangement for other layout classes, since it relies too much on links' and nodes' correspondence to source code constructs.
If you need to arrange only links after nodes have been arranged, try calling:
diagram.RouteAllLinks();
or:
new OrthogonalRouter().Arrange(diagram);
esri_test
Reply #7 - Aug 22nd, 2013 at 7:02pm
Thank you, Stoyan!
I used this one:
it looks much better!
