Normal Topic Appointment Headers (Read 3873 times)
ColinA
Appointment Headers
Sep 3rd, 2013 at 9:03am
Hi
I'm trying to set the header to a solid color but tries the .style  and no luck so far
Cheers
Colin
ColinA
Re: Appointment Headers
Reply #1 - Sep 3rd, 2013 at 9:46am
using .Style.Brush = New MindFusion.Drawing.SolidBrush(Color.Green)  set the whole app to green but using Style.HeaderBrush = New MindFusion.Drawing.SolidBrush(Color.Green)  doesn't seem to have any effect  must be missing something Sad  I just want to color the header area
Reply #2 - Sep 3rd, 2013 at 10:39am
It is not possible to style only the header area of an appointment (Style.HeaderBrush does not seem to be used for items). You need to rely on custom drawing to paint the header in different color. To do this, set Calendar.CustomDraw to CustomDrawElements.TimetableItem and handle the Calendar.Draw event. In the event handler use the following code:
// Calculate the header area
Rectangle r = new Rectangle(e.Bounds.X + 1, e.Bounds.Y + 1,
    e.Bounds.Width - 2, weekView.ItemSettings.HeaderSize);
// Fill the header area
e.Graphics.FillRectangle(Brushes.Red, r);
// Redraw the header text
SolidBrush textBrush = new SolidBrush(e.Style.HeaderTextColor);
StringFormat textFormat = new StringFormat(StringFormat.GenericTypographic);
textFormat.Alignment = StringAlignment.Center;
textFormat.LineAlignment = StringAlignment.Center;
e.Graphics.DrawString(e.Item.HeaderText, e.Style.HeaderFont, textBrush, r, textFormat);
textFormat.Dispose();
textBrush.Dispose();
Note that you need to redraw the header text as well. Otherwise, the header text will not be visible after you fill the header area with your custom color, because the custom drawing occurs after the default drawing of the item.
ColinA
Reply #3 - Sep 3rd, 2013 at 11:07am
Hi Meppy
Thanks for that  1 proble
e.Graphics.DrawString(e.Item.HeaderText, e.Style.HeaderFont, textBrush, r, textFormat)  give the error
value of type mindfusion.drawing.solidbrush cannot be converted to system.drawing.brush
Reply #4 - Sep 3rd, 2013 at 11:27am
Use the full System.Drawing.SolidBrush name:
System.Drawing.SolidBrush textBrush = new System.Drawing.SolidBrush(e.Style.HeaderTextColor);
